nah you need special solvents.
THF works good. Flux remover (like the rosin flux remover from the can) works good, its some kinda freon.
It basically makes it "constrict" and lose adhesion, then you can just peel it off with a stiff brush (ESD SAFE ONLY)
ALcohol has little effect, Acetone I am not sure.
The best stuff is here
https://mgchemicals.com/products/conformal-coatings/conformal-coating-stripper/conformal-coating-remover/It has acetone, combined with 2 other solvents. Solvent combination is necessary. Often when you mix solvents, its better then just pure solvent for dissolving. They do experiments to see which mixtures effect the glues the best.
Alcohol is used for rework, so they pick a glue that does not get effected by alcohol too much.
Now, there are stronger coatings, like paralyene and stuff... that are a bitch. Those you need to use heat, i.e. a pace lap-flow tool, which is basically a scraper that is resistance heated. You heat it up to a depolymerization temperature of the glue, and then scrap. But that is a expensive vapor deposited coating (vacuum oven required). Usually only found in government equipment, like space parts. I don't think I ever came across it, but there is plenty of info about it.
Also, epoxy is kinda hard.. but its not the best coating anyway.
I found that basically MG chemical conformal coating remover worked on anything I ever come across. If I wanna do a 'neat' job, i.e. a repair on a nice board, where I don't want to risk peeling the coating, I use the lap-flow scraper tool at low temperature to remove the coating, or a abrasive rubber burr, followed by damp q-tip cleaning of the residue.
Being able to work on conformal coating nicely, is a skill IMO... I am sure there is people that are really good at it, at the repairs department of NASA or something. I find it completely obnoxious. That is the same skill as a beauty salon worker, work with smelly chemicals and skin peels.
. They use the same tools too. I imagine a slightly overweight woman with streaks in hair and 1/2 inch long nails doing this job "nicely" while on phone. I just recommend dousing and scrubbing with a ESD safe brush when its all deformed, followed up by ultrasonic cleaning (its really hard to get the board "clean" at a magnifier level, there is always little curls of coating left behind.
