Oh yeah, but there is another method you can use to increase your reliability to 100% for the repair
you cut all the parts off at the base of the part with flush cutters (fine tip), remove the part, then heat each lead individually and pull it with tweezers. it wrecks the old parts but its what I basically always do because its just better
I would only bother desoldering a part properly if its worth at least $10 and I have a feeling that its ok (i.e. to isolate part of troublsome circuit)
this is more then good enough
https://www.amazon.com/Xcelite-170M-General-Shearcutter-Diagonal/dp/B0002BBZISthis is total overkill
https://tronex.descoindustries.com/Tronex-Catalog/Cutters/Tip-Cutters/5049/then you solder on the new parts with a soldering iron, you can even glue it down with a tiny dot of hot glue to make it easy. Wick out the holes with fine solder braid, or a solder extractor, or if those two fail, you can use a air blower to blow out the solder to the other side (messy and requires very detailed inspection to make sure you did not short something with a errant solder blob)
You only have a SOIC part. The tear drops might start when you have a heat sinked no-leads part, then you can't cut them off. A SOIC is just a squashed dip, you can cut them off! it has legs
And Ceramic is not that weak, i mean its weak compared to fiberglass but I have been using this ceramic substrate (ceramic utility knife blade) for my experiments
it survived multiple drops on the concrete floor and around 5 heat cycles, one to 1300C and 4 to 1000C, before it broke when I wanted to see if it still cuts into a bottle cap after all that (I forgot that I had initially sanded the edge off with diamonds to make it safe, otherwise it would probobly be fine). I even dropped it hot when it was like 600C the first time I took it out of the oven, because it slid off my oven plate when I put it into my cooling insulated brick
https://www.sliceproducts.com/products/ceramic-utility-bladesthey work for knives, I use them. I am telling you, your repair is easier then you think . Those ceramic substrates are not shitty clay pottery, its a hard core engineering material, they do all sorts of things a typical ceramic person does not do, like x-ray? porosity tests, density tests, cracking inspection, etc before it gets approved for circuit card use.
