Just out of curiosity, what are the common ways used to measure positive and negative voltage on multimeters?
I have searched online and looked at some schematics, but I couldn't find much.
What I came up with is that, after the voltage goes through the input dividers, it could have some offset added to it so it falls in the midpoint of the ADC's range (but then you loose half the resolution), or it could go through a precision rectifier and then to the ADC, having to detect beforehand if the voltage being measured is positive or negative.
Same thing with positive and negative current.
Any ideas?
Juan
