A few things to consider, it's the heat of fire with electricity so what could go wrong
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
Resistance wire in magnesium-oxide powder as the electrical insulator, just like your older stove heating elements, is what I imagine the kettle element uses for construction. The electrical insulation of the MgO, so you don't get a shock. Once you take it apart, it's a mess. It's designed for heating liquids, not air.
A hair-dryer heating element is very similar to the hot-air gun heating element, so maybe consider that, although operating temps are much lower so the materials (plastic) verses steel tube, porcelain insulator etc.
You can buy a 858D entire hot-air station for low cost, or the wand or heating element for very cheap. Less things melting for you.
