First, you want to discharge Li-ion cells, and because there will be more than one there will be high current and high power wasted.
- correct.
Second, you want to charge Li-ion cells using a solar panel.
- no , idea was to use solar input as load for battery discharge ( to not use resistive load ).
In the case of discharging the Li-ion cells, you do not want to use a resistive load because that will cause too much heat, so you want to use that energy to power something else with maybe an inverter.
- correct.
In the case of charging the Li-ion cells, you want to limit the current because it's too much for the cells to handle
- most probably , this I`ll limit with supply itself as I can have connection to BMS .
Hello,
Not sure what you mean when you say:
"idea was to use solar input as load for battery discharge ( to not use resistive load )".
I assume this is a solar panel?
Why would you want to use a solar panel as a load? Do you mean connect the solar panel to the batteries directly as a load? There would still be energy lost as heat in the solar panel.
I am not sure there has been much research on this but here are a few notes...
First, you would have to have enough voltage to push enough current through the panel. The panel looks like a lot of diodes in series so you'd have to have a high enough voltage to allow all those diodes to conduct. For example, for a typical 12v nominal panel you might need as much as 21 volts to get enough current to flow through it. It would act as a load, but the load current could not exceed the max current of the array.
Second, you might be taking a chance on this not hurting the solar panel.
I can guess that you want to use the panel because it's already available and it has a larger surface area so it may not get too hot. Resistors have a relatively small surface area so they get very hot with a lot of power, even though they may be rated for that power level.
This could work I would think, but you would need a boost converter to boost the cell voltage up to the right voltage for the panel if the panel was a typical 12v panel. The current through the panel would have to be limited that's for sure.
Perhaps you can test this idea with a lower cost panel first. To understand what will happen you can look deeper into what happens when you use rectifier diodes in series as a load. It can be done but you should look at the current/voltage characteristics doing it this way first.
Does the above sound like something you were thinking about for using the panel as a load?
