I need help figuring out how to interpret dump file data!
I'm working on a project that utilizes an S-24CXX series EEPROM (S24C02AD1Y1206). I am new to dump files and EEPROM programming but would like to learn to interpret the data and eventually be able to program my own data utilizing a T48 programmer. Currently I have been able to get Xgpro working to read the data off the chip (using the preset SEIKO S-24C02A @SOIC8) and then input the data into HxD. I am not sure how to do a byte swap with HxD or if i even need to byte swap the data. I will attach the dump data below. If it helps at all one of the numbers that should be stored on the chip is 628. I am hoping someone can point me in the right direction as to what i may be doing right or wrong and where i need to go from here. Thanks ahead of time!
Edit:
00 00 00 06 06 06 C7 C7 C7 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 92 27 06 96 27 06 04 00 00 00 00 00 00 00
00 28 06 04 28 06 04 04 28 06 08 28 06 0C 08 28
06 12 28 06 1A 12 28 06 16 28 06 04 16 28 06 20
28 06 36 20 28 06 24 28 06 04 24 28 06 28 28 06
0C 28 28 06 32 28 06 1A 32 28 06 36 28 06 04 36
28 06 40 28 06 76 40 28 06 44 28 06 04 44 28 06
48 28 06 0C 48 28 06 52 28 06 1A 52 28 06 56 28
06 04 56 28 06 60 28 06 36 60 28 06 64 28 06 04
64 28 06 68 28 06 0C 68 28 06 72 28 06 1A 72 27
06 76 27 06 04 76 27 06 80 27 06 F6 80 27 06 84
27 06 04 84 27 06 88 27 06 0C 88 27 06 92 27 06
1A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
