Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Earth wire connected between primary and secondary of isolated offline SMPS
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Earth wire connected between primary and secondary of isolated offline SMPS (Read 1198 times)
ocset
Super Contributor
Country:
on:
July 31, 2018, 07:20:39 pm »
We are noticing in many isolated offline SMPS’S , that there is an insulated earth connection wire connected between primary and secondary…it connects to output ground. Would you agree that this is for the purpose of preventing the SMPS output from floating up to high voltage levels with respect to Earth ground?
Logged
ArthurDent
Super Contributor
Country:
Re: Earth wire connected between primary and secondary of isolated offline SMPS
Reply #1 on:
July 31, 2018, 07:51:43 pm »
Yes, but not to any current carrying primary wire. Only to the ground (earth) wire that comes from the wall outlet.
Last Edit: July 31, 2018, 07:54:22 pm by ArthurDent
Logged
ocset
Gyro
Super Contributor
Country:
Reply #2 on:
July 31, 2018, 07:55:02 pm »
An odd question treez.
Yes, many SMPSs have grounded outputs. It provide a solid ground reference for whatever the SMPS is powering, for safely, static discharge protection, preventing Y cap leakage etc.
[Edit: I'd probably go as far as to say that
most
3 pin input SMPSs provide a grounded output]
Last Edit: July 31, 2018, 08:06:06 pm by Gyro
Logged
Best Regards, Chris
ocset
Giaime
Regular Contributor
Country:
Reply #3 on:
August 01, 2018, 08:12:46 am »
I think it's odd instead. Most SMPS I've seen are SELV type output, so they provide a basic insulation w.r.t. PE.
Many SMPS have a PE wire from primary side to secondary side, but that's just to connect to PE the output Y caps, for noise reduction.
Logged
ocset
lordvader88
Frequent Contributor
Country:
Reply #4 on:
August 07, 2018, 07:40:17 am »
I thought they usually have a blue, high voltage cap from pri to sec gnd. But I've only really worked on computer PSUs and little wallpack types.
Logged
ocset
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
