Author Topic: TACTILE SWITCH  (Read 3704 times)
Offline AbayomiTopic starter
  • Country: ng
TACTILE SWITCH
« on: September 12, 2016, 11:13:46 am »
How to use a tactile switch in together with flip flop or latch. That is, if I press the switch the flip flop the output toggles, when i release the switch the output hold its state, when I press the switch the output changes state
Offline Blastcap
Re: TACTILE SWITCH
« Reply #1 on: September 12, 2016, 11:38:58 am »
You mean like this?
Offline bitslice
Offline Brumby
Re: TACTILE SWITCH
« Reply #3 on: September 12, 2016, 01:13:07 pm »
Back to basics.....
Online tooki
Re: TACTILE SWITCH
« Reply #4 on: September 13, 2016, 12:43:50 pm »
Correct me if I'm wrong, but these days, isn't the absolute cheapest way to use an ATtiny MCU or something? As much as I love the idea of discrete components and jellybean logic chips, it seems MCUs do it far cheaper in the end...
Online Ian.M
Re: TACTILE SWITCH
« Reply #5 on: September 13, 2016, 01:11:51 pm »
That's only true if you have high enough volume, and can write off the one-time costs e.g. Microchip PIC10F200 can be bought from Microchip Direct for as little as $0.34 USD each, preprogrammed with your code, provided you are ordering more than two reels at a time (3000 per reel).   If you are only building 10 units, you are probably looking at half a day to write and test the debouncer and program all the chips, which could easily add $20 to the cost of each unit, by the time you've figured in wages and business overheads.
