Is that why, when simplifying circuits, we simplify the parallel elements into a single resistance and then add all of the resistors together like it were a series to find a single equivalent resistance?
We only add them together if they actually are in series.
Some circuits can't be simplified by just parallel and serial replacements. The simplest example is a bridge circuit.
That can still be solved using simple resistors in series/parallel calculations, along with Thevenin's theorem and Kirchhoff's law.
It can be treated as two potential dividers, which are equivalent to two voltage sources, each with a series resistance equal to both resistor values in series: Thevenin's theorem.
Remove R5 from the circuit.
Calculate:
V(pd1_open) and V(pd2_open)
V(pd1_open) = V1×R2/(R1+R2) = 5×100/(100+100) = 2.5V
V(pd2_open) = V1×R2/(R3+R4) = 5×100/(100+200) = 1.667V
The output impedance of pd1 and pd2, which is simply equivalent to the resistances in parallel.
R_pd1 = R1×R2/(R1+R2) = 100×100/(100+100) = 50R
R_pd2 = R3×R4/(R3+R4) = 200×100/(200+100) = 66.67R
Reinstate R5. The current can now be calculated using Ohm's law.
The voltage is equal to the open circuit voltages of the potential dividers.
It's the voltage difference, which is important, so they're subtracted.
V = V(pd1_open) - V(pd2_open) = 2.5-1.667 = 0.833V
To get the current, through R5, the impedance of the potential dividers needs to be added to R5:
R(total) = R(pd1) + R(pd2) + R5 = 50 + 66.67 + 50 = 166.67R
I = 0.833/166.67 = 0.005 = 5mA
We know the current through R5 and therefore pd1 and pd2 is 5mA, so the voltages with R5 in place can be calculated using Ohm's law. V(pd1) is higher than V(pd2) so we know that the voltage on V(pd1) will fall (hence the - sign) and the voltage on V(pd2) will rise (hence the + sign) when R5 is connected: Kirchhoff's voltage law.
V(pd1) = V(pd1_open) - R_pd1×I(R5) = 2.5-50×0.005 = 2.25V
V(pd2) = V(pd2_open) + R_pd2×I(R5) = 0.833+166.67×0.005 = 2V
The voltages on R2 and R4 equal v(pd1) and V(pd2) respectively, so the currents can be calculated:
V(R2) = V(pd1)
I(R2) = V(R2)/R2 = 2.25/100 = 0.0225 = 22.5mA
V(R4) = V(pd2)
I(R4) = V(R4)/R4 = 2/100 = 0.02 = 20mA
The total supply current is simply the sum of the currents in R2 and R4: Kirchhoff's current law.
I(V1) = I(R2)+I(R4) = 22.5mA + 20mA = 42.5mA
The total resistance can be calculated using Ohm's law:
R = V1/I = 5/0.0425 = 117.65R
If V1 is unknown, just replace it with 1. The end resistance value will be the same.
There are other ways to solve this, but this is my favourite one.
