Author Topic: Need help with the identity of this......  (Read 2337 times)
Offline lavo-1Topic starter
« on: January 09, 2012, 02:09:00 pm »
Hi chaps, I am hoping that some one will be able to help identify thIs transformer. It is from a MetraPat 4 Pat tester.
The primary coil is O/C and thus I am unable to measure what the output from the secondary.
I have looked on a few parts catolouges such as Digikey and RS but none of the numbers from the casing seem to match anything.
Could this be a bespoke component that I will have to get from Gossen? I can hear my wallet groan as I type!
Would love some help or advise on getting a replacement part.
The numbers on the case:
3.520.057.02
M19-092 A
GT 07/97
Uploaded with ImageShack.us
Shot at 2012-01-09
« Last Edit: January 09, 2012, 02:14:03 pm by lavo-1 »
Offline amspire
Re: Need help with the identity of this......
« Reply #1 on: January 09, 2012, 11:45:17 pm »
The transformer is likely to be one made specially for Gossen. If you can afford a replacement from Gossen, that is the best solution. It may have higher insulation ratings then conventional transformers, or extra shielding.
It may be possible to substitute it with an off-the-shelf transformer functionally. If there is room in the case for a second transformer, it may be possible to keep using the original, and feed voltage into one of the secondaries from a second transformer. Any clues to voltages, like voltages marked on the PCB may help. You would need to work out how the windings on the secondary are configured, and then by applying 50.60hz AC to one of the secondary windings, measure all the ratios of the other windings to the first, along with the DC resistance of each winding. That would be a start anyway.
It would help if you can get a schematic, but I haven't seen many Gossen service manuals floating around.
If you want the meter though to perform to the original safety specs, you probably better go talk to Gossen.
Richard.
« Reply #2 on: January 10, 2012, 07:56:42 am »
Many thanks for the reply Richard.
It does look like I will have to just get in touch with Gossen and see what they say as I am unable to locate a schematic to try to match a third party transformer.
I will post any further developments when I get a reply from Gossen.
Thanks again.
Jason.
« Last Edit: January 10, 2012, 10:04:45 am by lavo-1 »
