Author Topic: Looking for a ESR meter  (Read 4614 times)
Offline mapleLC
Re: Looking for a ESR meter
« Reply #50 on: June 16, 2022, 08:51:48 am »
Post one so we are not guessing
The YouTubers I have in mind are:
 John Ward - he uses his Fluke multi function tester in insulation test mode to check a run / start motor capacitor
and
Bill - Lockdown Electronics - he recreates w2aew's procedure to measure the esr with an oscilloscope and function generator, but goes on to test with an insulation tester (much like above)
[Ed to add #744 IMSAI Guy]
So you might not need any fancy equipment but chasing down all those specs with every single cap you come across?  That's cumbersome.
Offline armandine2
« Reply #51 on: June 16, 2022, 11:10:49 am »
fancy equipment, or not, it becomes a fetish soon enough.
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
The following users thanked this post: mapleLC
Offline Doctorandus_P
« Reply #52 on: June 18, 2022, 09:19:10 pm »
For anyone thinking (or curious) about home-built ESR meters, have a look at:
 http://kripton2035.free.fr/esr-repository.html
The following users thanked this post: kripton2035
