Hi there,
I'm new to a job which requires measuring the temperature and humidity of the environment. I've been given a spot meter (Precision Gold N21FR) to take readings, but just wondering for future reference how I change the battery? The instruction manual says to remove the screws in the cover, but I see no screws! The yellow part I'm assuming is the cover and it is loose around the sides of the monitor (see attached photos) but it doesn't seem to want to come off. Any thoughts much appreciated!
Katherine
