If you are 100% sure there will never be any transients, you can use a 0603 part if you can find one rated for 200V.
High voltages and miniaturization do not play along easily. It's possible but requires special procedures.
If this is voltage divider off something mains-derived, use resistors rated for 600-1000V or so. It's very typical to use two or three through hole parts, each rated for 300V, in series. This is because mains will have transients, and you don't want arc-overs, each time materials will carbonize and slowly start conducting.
