Google is your friend - for some of them anyway...
The AY-3-1015D is a UART
The Tandy chip is a PAL - probably programmed for some Tandy product.
The 7494 is a standard TTL 4 bit shift register
The one with 150 Ohm on it is almost certainly a resistor pack
The 930 and 960 are DTL (diode-transistor) Logic chips
P.S. Welcome to the forum.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
