By my understanding , its difficult for everyone to start giving opinions about test equipment .
I am not the right person but I will try to help just a bit ..
First of , your Geographic location as country on the map , could help us, so to determine , the brands that you can possibly find ..
As second , your cost estimate, sounds too low, for an such a task.
So the first advice could be, to check first for used instruments.
Before you even start asking for brands and models , you have to make your planing, and for example,
to write on paper your specific requirements for its device.
Example : one DC power supply that must do 35V 10A with current limiter , and if you wish triple outputs , then you will have to spent 2000$ just for that .. so to be new and properly calibrated from the factory.
Quality
Control testing , needs tremendously expensive equipment , and even just one of every type, its not enough.
I bet that you are an freelancer or student , and just looking for quick tips, its not bad as tactic
But I can not help you , with quick tips , because I respect the screwdriver that I hold for years in my hand, and such decisions about getting the proper tools , does not work as an quick shopping list.
I am always speaking in positive spirit , if the translation does not prove that , just ignore my message.
