Datasheet: http://www.quartz1.com/price/PIC/405N3134800.pdf
The test jig circuit has a bypass cap, so you should use one. Also pin 1 is output enable and should be tied high.
Excellent find with the datasheet That's really helpful, thanks. The eBay description didn't mention the enable pin, which I guess is either pulled up internally or I just got lucky, because it works floating. I'll make sure to tie it high now. Thanks again.
I aquired about 200 20mhz oscillators just like that as part of an ebay score somewhere, after using about 4, having fun dremeling open some others and watching what happens when i take a sharpie to the crystal to tune it, I have roughly 190 left. If someone wants a couple I'll send em for the price of postage from southern california.
For some reason, occasionally those oscillator modules come up in bulk for insanely cheap on ebay, usually loose with bent leads. maybe someone knocks over a bin at the factory and they sweep em up and put em online? I never had issues , appear within spec according to my standard so I don't think they are factory rejects. I always use them for self-made boards to just not worry about getting the capacitance/layout right for stable crystal starting up. that and i have a couple hundred to use up... When all you have is a bin of 20mhz oscillators, everything looks like something that should run at 20mhz...
