i found the board that the right transformer came off of and it does come from UK 230 50Hz mains, it has a few 0.1uF caps with it and the bridge rectifier alone with smoothing caps and other componants.
comming off the board are connectors with labels :
P-con, GND, aL5V, -8V, GND, 8V, GND, AL5V, GND, 3.7V
D5V GND, A5V GND, 8V, GND
GND, -28V, AL5V, VF+, VF-
-8V, GND, 8V, D5V
i think this board came off of a DVD player with a VHD display
on the right transformer there is 1 pin with a space then 4 pins in a row and on the other side there is 1 pin then a space then 7 pins in a row if thats any help
