Author Topic: Setting up experiment problem-No Waveform  (Read 2203 times)
Offline gotwoodTopic starter
« on: May 08, 2013, 11:53:42 pm »
I need a 10 mV AC supply for an amplifier circuit
My function generator only goes down to 100mV pp.
I figure I would use resistors as a voltage divider or a variable pot.
Well, the bigger problem is my Agilent 54645D Mixed-Signal Oscilloscope is not reading a sine wave at that low of an amplitude.
Any ideas of what I could be doing wrong?
I've only had 2 resistors or the variable pot hooked up to the FG.
And the oscilloscope hooked up at the same ground and divider junction.
Forgot to add.....1Khz
Pot is 5K ohm
« Last Edit: May 08, 2013, 11:56:51 pm by gotwood »
Offline croberts
Re: Setting up experiment problem-No Waveform
« Reply #1 on: May 09, 2013, 12:15:00 am »
You probably want to use a 1x probe (not 10x)?
« Reply #2 on: May 09, 2013, 12:21:32 am »
I'm using some mini grabbers...pamona brand
Offline croberts
« Reply #3 on: May 09, 2013, 12:28:45 am »
How are you connecting those to the scope BNC connectors ?
« Reply #4 on: May 09, 2013, 12:32:14 am »
Yes, they are purchased as such
Offline croberts
« Reply #5 on: May 09, 2013, 12:45:12 am »
Can you provide a schematic of your test set up? What exactly are you seeing on the scope screen? A straight line or no line. Are you AC or DC coupled?
« Reply #6 on: May 09, 2013, 12:56:19 am »
Both couplings look the same......not sure how to describe except looks like bunch of lines packed together with intermittent spikes
                          Ground
FG 100 mV pp                      Oscilloscope
                     R1.                                        R2.   -ground
