Author Topic: Do you know the KORAD KEL-103 - Programmable DC Electronic Load?  (Read 4849 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: December 08, 2018, 05:07:54 pm »
I have looked (still saving money for my first bye) on the different loads and stumbled on the KORAD KEL-103 - Programmable DC Electronic Load, 300 Watt, Low Ripple: https://www.amazon.com/gp/product/B07GVNQZQF/ref=ox_sc_saved_title_6?smid=AKJ57Q9VZBBO8&psc=1
Du you know anything about this electronic load?
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Offline salvagedcircuitry
  • Electrical Engineer | Hobbyist | Camera Enthusiast
    • salvagedcircuitry
Re: Do you know the KORAD KEL-103 - Programmable DC Electronic Load?
« Reply #2 on: January 10, 2019, 07:51:50 am »
Interesting find. I also ran into this DC load on amazon today too. It looks like it may be based off the itech design, but I can't say for certain. The entire front panel looks completely different and the rear panel has usb and ethernet - not found on any other dc electronic load of this size. Ethernet is not present on the Bk precision, itech, mayuno, Applent, Array/Atten or Tonghui units. This is definitely an interesting unit. I wonder if anyone has one?
Here's the ebay listing from the same seller:
https://www.ebay.com/itm/132760029322
« Last Edit: January 10, 2019, 07:55:32 am by salvagedcircuitry »
    • salvagedcircuitry
« Reply #3 on: January 10, 2019, 06:14:26 pm »
Some more info:
The Korad website seems to be down or gone, which does not instill confidence.
KEL-103 manual with specifications. The specs are very close to the BK 8601.
https://www.sra-shops.com/docs/srasolder/instructions/kel-103_user_manual.pdf
It looks like this KEL-103 is identical to the TENMA 72-13210 dc electronic load sold by farnell:
https://uk.farnell.com/tenma/72-13210/dc-electronic-load-prog-30a-120v/dp/2848407
https://www.farnell.com/datasheets/2602709.pdf
However, it looks like this is a very un-finished unit:
https://www.element14.com/community/thread/64903/l/need-windows-usb-driver-for-tenma-72-13210-electronic-dc-load-30a120v-300w
I would love to see a teardown of this unit regardless!
Offline beltet
« Reply #4 on: March 07, 2019, 04:03:23 pm »
Korad has good reputation on their lab power supplys. Good value.
I am looking at this as well. When I have the money I want to test this out.
Offline rdl
« Reply #5 on: March 08, 2019, 03:29:33 am »
Best I remember, Tenma was the house brand for MCM Electronics which was acquired by Newark a while back. Just about everything sold under the Tenma name was made by somebody else and rebranded, so it probably is a Korad.
Offline pshersby
« Reply #6 on: March 13, 2019, 12:23:55 am »
I just took a look in mine - PCB is Korad version 2.9
