Author Topic: What is the best way to make printed circuit boards at home?  (Read 7586 times)
Offline KL27x
Re: What is the best way to make printed circuit boards at home?
« Reply #50 on: May 25, 2020, 02:43:43 am »
Why you make your boards at 10 if 5 worked? Was 5 more effort or some chance of failure in resist or etch? (I assume the manufacturers charge more for sub 7 or so mil traces for actual reasons.)
The way I line up a double sided board is by drilling two holes in the papers. Transfer one side and drill the pcb through the 2 holes in that paper. Then put the second side on and line up the holes. Stick that side. Then remove both papers and etch. I don't know what kind of accuracy you need, but this isn't hard or iffy to complete. It is just time-consuming. You save a lot of time elsewhere, though.
If this is a DIY board, only, I might enlarge my vias. But if it might go into production, I will just work with 15 mil vias, 8/8 default traces. The drill holes might break the annular ring on one side, but I will get everything working just fine. So I actually make DIY boards almost exactly the same as production boards, no problems (although I may increase the clearance around pads, due to lack of a soldermask layer; and I can't put vias under SMD IC's). Using 8/8 traces is not "showing off." It's the size that is easiest to route for me, and also once you find the smallest size of traces that does not cause additional issues, you are making your board MORE reliable by reducing the area of the board. The larger your boards, all else equal, the more chance of a failure. With the right process (I assure it is easy), 8/8 is just as reliable as 20 mil traces. So this allows more complex and/or larger boards without adding more work, prep, scrubbing, or chance of a failure due to lack of attention over that larger area.
You can have issues with many toner transfer papers due to distortion. There's no one forcing you to use these inferior papers, though. Magazine paper was the worst, I tried. Enough distortion to cause problems on larger boards. But there are other reasons I would not use magazine paper, anyway.
In short: 90% of people who use UV, it's because they learned toner transfer from internet hacks, and they (quite reasonably) gave up before sorting through the different options, from "make a crappy PCB for free with shit that is in your house right now" to actual pro-level toner transfer. For most people, toner transfer is the better way to go so long as you don't try to cheap out. UV might be cheaper to get into, initially, esp if you don't have a suitable laser printer. But toner transfer is easier and faster in the long run, and in that long run, both methods are dirt cheap. The labor is what matters.
If you are the kind of guy that will spend $100 dollars on various mystical photo papers trying to find a lifetime supply of pcb paper for cheap, well then you can waste years learning subpar toner transfer, trying to convince yourself your latest underground bargain score paper, learned from some dude on the internet, will eventually work perfectly with enough practice. I'm guilty. I got through it, though. I also come to believe that most of us don't know what "perfectly" means when we say it. When we sometimes get something that looks very much like pictures what other people get (from 5 feet away), we assume we "got it." Making a PCB is about reproducing fine details reliably. You have to pay attention to details and consistency to know if your way is "the best."
« Last Edit: May 25, 2020, 09:06:18 pm by KL27x »
Offline SilverSolder
« Reply #51 on: May 25, 2020, 10:57:46 pm »
You can master toner transfer to 100% success rate, too.
No doubt about that with one layer but I have some doubts with two layers. I couldn't.
I found that putting the toner transfer paper on a light table, I could "see enough" to get good alignment.  Then I staple or tape the papers together, just like the transparencies.
But I have never been able to get as fine detail with toner transfer as with the inkjet method (and yes, I have seen distortion due to the heat involved in laser printing).
For many projects, though, you don't need max precision and the ease of use of toner transfer makes it a winner.
I'm also leaning towards just getting the boards made nowadays,  in all honesty.   At the low prices you can get them made for, there is no way it is economical to DIY.  So then there is just the "fast turnaround" aspect, and the "fun hobby" aspect left -  which are still good enough reasons to have a go!
Offline KL27x
« Reply #52 on: May 25, 2020, 11:12:02 pm »
deleted for being irrelevant to the thread.
« Last Edit: May 26, 2020, 06:00:11 am by KL27x »
