Author Topic: looking for waterproof barrel jack connector  (Read 5381 times)
Offline V_KingTopic starter
« on: November 23, 2014, 11:13:40 pm »
Hello,
I wonder if anybody could help me to find in UK waterproof barrel jack connectors as shown below.
more info here
http://www.diytrade.com/china/pd/9807813/dc_plug_connector_waterproof_cable_3_5_dc_connector.html
it would be great to find something with good wire and at least 5A rating at 12VDC.
There some connectors in farnell and ebay with screw type seal, but I just need one, which clips together.
China suppliers are not an option, as I need them for next week
Cheers
Offline Tandy
  • Darren Grant from Tandy, UK.
    • Tandy
Re: looking for waterproof barrel jack connector
« Reply #1 on: November 24, 2014, 12:24:47 am »
Those are moulded connectors where the wire has been soldered to the terminals and then the housing injection moulded onto the cable. Barrel connectors that you can put on yourself won't be watertight. There seems little point having the cable entry waterproof when the connector itself has no way of being protected from water.
For more info on Tandy try these links Tandy History EEVBlog Thread & Official Tandy Website
Offline sparx
« Reply #2 on: November 24, 2014, 02:01:28 am »
Would something like this suffice? Fairly cheap, and UK shipped.
Electrical Waterproof Connector 1 2 3 4 5 6 Pin Way Superseal Car Boat Kit Clip
Online Zero999
  • 0999
« Reply #3 on: November 24, 2014, 10:42:07 am »
How waterproof does it need to be?
Does it just need to be protected against cleaning or is it going to be submersed in several meters for days?
What IP rating do you need?
Online tggzzz
« Reply #4 on: November 24, 2014, 10:49:42 am »
If you look up the "IP" waterproof ratings and define what you need, it will be easy to search distributors' catalogues for an appropriate  IP** connector.
You may need to take care with that cable, since a figure-of-eight cross-section might be a problem w.r.t getting a good seal.
Offline corrado33
« Reply #5 on: November 24, 2014, 05:10:17 pm »
batteryspace has some lockable "waterproof" barrel connectors similar to the ones you posted above. I have the same type (different company) on my bike light and it works well. I googled it, they do ship to the UK, although they're based in the US.
http://www.batteryspace.com/trail-techcoaxislockableplugwithcable.aspx
« Reply #6 on: November 24, 2014, 10:35:20 pm »
Thanks for the answers. The wiring will be outdoors, so it is basically has to be splash proof. No submersion will be performed. An usually such connectors do come already with wiring or rubber sealing on the cable entry point.
when you start putting in IP ratings in the catalog like farnell, you get the screw together ones, but I need to be able to quickly disconnect them quite often.
