Author Topic: GLCD Ks0108 Code not working  (Read 1336 times)
Offline Vindhyachal.taknikiTopic starter
« on: October 06, 2017, 01:16:39 pm »
1. I have modified a code  library for GLCD Ks0108 type.
2. Nothing is getting displayed on GLCD in code.
3. I have checked individual pins by set & reset them on CRO, so they are ok.
4. MCU is running at 120Mhz core, library had 5 Nops by default in function glcd_delay() & it was written for 8Mhz. As my MCU is running at 120Mhz, so I had added 15 times more Nops.
5. Able to debug through code no issues but nothing is displaying on lcd.
6. here is the link for code. It has four files: main.c, glcd.c, glcd.h, fonts.h.
glcd.c I am adding in this forum, rest can be seen on google drive here: https://drive.google.com/open?id=0B-jbeBk3wfkWWklpa2piSjdGLUk
7. MCU i am using is STM32F205RBT6, but I think it is more of initialization issue.
#include "stm32f2xx.h"
#include "glcd.h"
#define KS0108_SCREEN_WIDTH     128
#define KS0108_SCREEN_HEIGHT 64
#define DISPLAY_SET_Y       0x40
#define DISPLAY_SET_X       0xB8
#define DISPLAY_START_LINE  0xC0
#define DISPLAY_ON_CMD 0x3E
  #define ON 0x01
  #define OFF 0x00
#define DISPLAY_STATUS_BUSY 0x80
uint8_t screen_x = 0U;
uint8_t screen_y = 0U;
 *  @function : void glcd_bitmap(char * bmp , uint8_t x, uint8_t y , uint8_t dx , uint8_t dy)
 *  @brief    :
 *  @parameter:
 *  @return   :
    uint8_t i;
    uint8_t j;
    for(j = 0U ; j < dy / 8U ; j++)
        glcd_go_to(x , y + j);
        for(i = 0U ; i < dx ; i++)
            glcd_write_data(glcd_read_byte_from_ROM_memory(bmp++));
} /* function ends here */
 *  @function : void glcd_set_pixel(uint8_t x , uint8_t y , uint8_t color)
 *  @brief    :
 *  @parameter:
 *  @return   :
    uint8_t tmp;
    glcd_go_to(x , y/8U);
    tmp = glcd_read_data();
    if(color)
        tmp = tmp | (1U << (y%8U));
    else
        tmp = tmp & (~(1U << (y%8U)));
    glcd_write_data(tmp);
 *  @function : void glcd_write_string(char *string_to_write)
 *  @brief    :
 *  @parameter:
 *  @return   :
    while(*string_to_write)
        glcd_write_char(*string_to_write++);
 *  @function : void glcd_write_char(char char_to_write)
 *  @brief    :
 *  @parameter:
 *  @return   :
    uint8_t i;
    char_to_write = char_to_write - 32;
    for(i = 0U ; i < 5U ; i++)
        glcd_write_data(glcd_read_byte_from_ROM_memory((char *)(font5x8 + (5 * char_to_write) + i)));
    glcd_write_data(0x00);
 *  @function : void glcd_clear_screen(void)
 *  @brief    :
 *  @parameter:
 *  @return   :
    uint8_t i;
    uint8_t j;
    for(j = 0U ; j < KS0108_SCREEN_HEIGHT / 8U ; j++)
        glcd_go_to(0U , j);
        for(i = 0U ; i < KS0108_SCREEN_WIDTH ; i++)
            glcd_write_data(0x00U);
 *  @function : void glcd_text_go_to(uint8_t x , uint8_t y)
 *  @brief    :
 *  @parameter:
 *  @return   :
    glcd_go_to(x*6,y);
 *  @function : void glcd_go_to(uint8_t x, uint8_t y)
 *  @brief    :
 *  @parameter:
 *  @return   :
    uint8_t i;
    screen_x = x;
    screen_y = y;
    for(i = 0; i < KS0108_SCREEN_WIDTH / 64U; i++)
      glcd_write_command(DISPLAY_SET_Y | 0 , i);
      glcd_write_command(DISPLAY_SET_X | y , i);
      glcd_write_command(DISPLAY_START_LINE | 0,i);
    glcd_write_command((DISPLAY_SET_Y | (x % 64)) , (x / 64));
    glcd_write_command((DISPLAY_SET_X | y) , (x / 64));
 *  @function : void glcd_initialize(void)
 *  @brief    :
 *  @parameter:
 *  @return   :
    uint8_t i;
    glcd_initialize_ports();
    for(i = 0U; i < 3U; i++)
        glcd_write_command((DISPLAY_ON_CMD | ON), i);
 *  @function : unsigned char glcd_read_byte_from_ROM_memory(char * ptr)
 *  @brief    :
 *  @parameter:
 *  @return   :
    return *(ptr);
 *  @function : void glcd_initialize_ports(void)
 *  @brief    :
 *  @parameter:
 *  @return   :
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOB , ENABLE );
    GPIO_InitStructure.GPIO_Pin   =   GPIO_Pin_3 | GPIO_Pin_4
                                    | GPIO_Pin_5 | GPIO_Pin_6
                                    | GPIO_Pin_7 | GPIO_Pin_8
                                    | GPIO_Pin_9 | GPIO_Pin_12
                                    | GPIO_Pin_13 | GPIO_Pin_14
                                    | GPIO_Pin_15;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOC , ENABLE );
    GPIO_InitStructure.GPIO_Pin   =   GPIO_Pin_0 | GPIO_Pin_1;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    GLCD_CS1_SET();
    GLCD_CS2_SET();
    GLCD_CS3_SET();
    GLCD_RS_SET();
    GLCD_RW_SET();
    GLCD_DB0_SET();
    GLCD_DB1_SET();
    GLCD_DB2_SET();
    GLCD_DB3_SET();
    GLCD_DB4_SET();
    GLCD_DB5_SET();
    GLCD_DB6_SET();
    GLCD_DB7_SET();
 *  @function : void glcd_write_data(uint8_t data_to_write)
 *  @brief    :
 *  @parameter:
 *  @return   :
    while( glcd_read_status(screen_x / 64U) & DISPLAY_STATUS_BUSY );
/* make port as output */
    GPIO_StructInit(&GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin   =   GPIO_Pin_6 | GPIO_Pin_7
                                    | GPIO_Pin_8 | GPIO_Pin_9
                                    | GPIO_Pin_12 | GPIO_Pin_13
                                    | GPIO_Pin_14 | GPIO_Pin_15;
    GLCD_RW_RESET();
    glcd_delay();
    GLCD_RS_SET();
    glcd_delay();
    if(data_to_write & 0x01U) { GLCD_DB0_SET(); } else{ GLCD_DB0_RESET(); }
    if(data_to_write & 0x02U) { GLCD_DB1_SET(); } else{ GLCD_DB1_RESET(); }
    if(data_to_write & 0x04U) { GLCD_DB2_SET(); } else{ GLCD_DB2_RESET(); }
    if(data_to_write & 0x08U) { GLCD_DB3_SET(); } else{ GLCD_DB3_RESET(); }
    if(data_to_write & 0x10U) { GLCD_DB4_SET(); } else{ GLCD_DB4_RESET(); }
    if(data_to_write & 0x20U) { GLCD_DB5_SET(); } else{ GLCD_DB5_RESET(); }
    if(data_to_write & 0x40U) { GLCD_DB6_SET(); } else{ GLCD_DB6_RESET(); }
    if(data_to_write & 0x80U) { GLCD_DB7_SET(); } else{ GLCD_DB7_RESET(); }
    glcd_delay();
    glcd_enable_controller(screen_x / 64U);
    glcd_delay();
    GLCD_EN_SET();
    glcd_delay();
    GLCD_EN_RESET();
    glcd_delay();
    glcd_disable_controller(screen_x / 64U);
    screen_x++;
 *  @function : uint8_t glcd_read_data(void)
 *  @brief    :
 *  @parameter:
 *  @return   :
    uint8_t status;
/* make port as input */
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IN;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
    GLCD_RW_SET();
    GLCD_RS_SET();
    glcd_delay();
    GLCD_EN_SET();
    glcd_delay();
/* read status */
    status = 0U;
    if(GLCD_DB0_VALUE()) { status = status | 0x01U; }
    if(GLCD_DB1_VALUE()) { status = status | 0x02U; }
    if(GLCD_DB2_VALUE()) { status = status | 0x04U; }
    if(GLCD_DB3_VALUE()) { status = status | 0x08U; }
    if(GLCD_DB4_VALUE()) { status = status | 0x10U; }
    if(GLCD_DB5_VALUE()) { status = status | 0x20U; }
    if(GLCD_DB6_VALUE()) { status = status | 0x40U; }
    if(GLCD_DB7_VALUE()) { status = status | 0x80U; }
    GLCD_EN_RESET();
    screen_x++;
    return status;
 *  @function : void glcd_write_command(uint8_t command_to_write, uint8_t controller)
 *  @brief    :
 *  @parameter:
 *  @return   :
    while( glcd_read_status(controller)  &  DISPLAY_STATUS_BUSY);
    GLCD_RW_RESET();
    GLCD_RS_RESET();
    glcd_delay();
    glcd_enable_controller(controller);
    glcd_delay();
    if(command_to_write & 0x01U) { GLCD_DB0_SET(); } else{ GLCD_DB0_RESET(); }
    if(command_to_write & 0x02U) { GLCD_DB1_SET(); } else{ GLCD_DB1_RESET(); }
    if(command_to_write & 0x04U) { GLCD_DB2_SET(); } else{ GLCD_DB2_RESET(); }
    if(command_to_write & 0x08U) { GLCD_DB3_SET(); } else{ GLCD_DB3_RESET(); }
    if(command_to_write & 0x10U) { GLCD_DB4_SET(); } else{ GLCD_DB4_RESET(); }
    if(command_to_write & 0x20U) { GLCD_DB5_SET(); } else{ GLCD_DB5_RESET(); }
    if(command_to_write & 0x40U) { GLCD_DB6_SET(); } else{ GLCD_DB6_RESET(); }
    if(command_to_write & 0x80U) { GLCD_DB7_SET(); } else{ GLCD_DB7_RESET(); }
    glcd_delay();
    GLCD_EN_SET();
    glcd_delay();
    GLCD_EN_RESET();
    glcd_delay();
    glcd_disable_controller(controller);
 *  @function : uint8_t glcd_read_status(uint8_t controller)
 *  @brief    :
 *  @parameter:
 *  @return   :
    uint8_t status;
    GLCD_RW_SET();
    GLCD_RS_RESET();
    glcd_delay();
    GLCD_EN_SET();
    glcd_delay();
/* read status */
    status = 0U;
    GLCD_EN_RESET();
    return status;
 *  @function : void glcd_disable_controller(uint8_t controller)
 *  @brief    :
 *  @parameter:
 *  @return   :
    switch(controller)
        case 0:
            GLCD_CS1_SET();
        break;
        case 1:
            GLCD_CS2_SET();
        break;
        case 2:
            GLCD_CS3_SET();
        break;
        default:
        break;
 *  @function : void glcd_enable_controller(uint8_t controller)
 *  @brief    :
 *  @parameter:
 *  @return   :
    switch(controller)
        case 0:
            GLCD_CS1_RESET();
        break;
        case 1:
            GLCD_CS2_RESET();
        break;
        case 2:
            GLCD_CS3_RESET();
        break;
        default:
        break;
 *  @function : void glcd_delay(void)
 *  @brief    : library had 5 delays for 8mhz, so adding 15 times more delays for 120Mhz
 *  @parameter: none
 *  @return   : none
    __NOP(); __NOP(); __NOP(); __NOP(); __NOP();
/************************************** End Of File ***************************************************************/
Re: GLCD Ks0108 Code not working
« Reply #1 on: October 18, 2017, 07:13:54 am »
Any update on it
Offline CJay
« Reply #2 on: October 18, 2017, 08:38:12 am »
Which CPU/Language suite was the code library written for originally?
Are you aware that a CPU with 8MHz clock input may further divide that clock internally for the 'instruction' clock so 8MHz may actually be an effective 2MHz or 1MHz, that means your code may still be far too fast for the GLCD?
« Reply #3 on: October 20, 2017, 05:49:01 am »
It was written for Atmel & same for STM32,
I have added 100us delay instead of NOPS, still nothing works
