Anyone can post on the internet, no need to show his diploma, nor to prove his skills, experience and knowledge ..... So, we must be careful because there is plenty of stupidity on the Internet ....
Fortunately, there are real experts on this forum who can correct mistakes, which makes EEVblog forum one of the best forums in electricity and electronics.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
The bulb lights up or not .... First, did you ask yourself what bulb ? 25W, 40W, 60W, 75W or 100W? ....
If not specified, it smell bullshit...
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
The magnetization current depends on:
- power of the transformer
- quality of the magnetic core (losses by eddy currents and hysteresis, gap, leakage flux, ....)
- induction level.
NB: the magnetization current is highly distorded, use only a true rms meter to measure it.
What is the normal magnetization current?
It depends on many factors, it can not be determined with a solution as simple as putting a bulb in series.
It is necessary to have a variac which makes it possible to apply a progressive voltage on the primary of the transformer, monitoring the current, and even to boost it up to 265V to check if there is no saturation of the core.
When saturation is reached, the magnetization current no longer increases linearly, it increases rapidly for a small increase in voltage.
As for the level of induction, it must be chosen according to the magnetic material used ....
I was manufacturing cheap transformers with low carbon steel (not silicon steel), so I used 10,000 Gauss (1T) .... for high quality magnetic steel (cold rolled high silicon steel) ) we can go up to 16,000 Gauss (1.6T), but be careful, because the saturation in a toroidal transformer is very sharp.
The toroidal transformer has not only advantages, it also has drawbacks, including high inrush current and low short circuit impedance.
