I could easily be wrong and/or misunderstanding you, but ...
It sounds like you have broken the PNP transistor, and it has gone short circuit, between (at least) the base and emitter.
When you incorrectly wired it up, previously, you could have broken it, because they don't like reverse voltages. Especially as regards "wrong" polarity on the base, at significantly high voltages (see datasheet, from memory limit is 5V in reverse direction).
If it was me, doing this, I might pull out the PNP from the breadboard, and use the diode test mode of a multimeter, and check the emitter/base junction, is still around 0.6/0.7 volts. If it is short circuited, then the PNP is toast.
Also, breadboards like that, are not particularly useful at higher currents, like the 2 amps you are using. They can easily be damaged and give poor results. They don't like hot components either (it can melt the plastic).
