Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Voltage reference max6070
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Voltage reference max6070 (Read 643 times)
bogdant
Regular Contributor
Country:
on:
January 24, 2020, 07:03:08 am »
I have the voltage reference max6070 the 3.3V variant used in my new power supply schematic. It is hooked to Vref from the microcontroller stm32f767. The schematic implemented is the one recommended by datasheet. But the output voltage is 4.6V, if the input is 5V. This is the first time when I use an voltage reference.
Here is the link to my schematic:
https://github.com/bogdan-tirzioru/Powersupply/blob/master/factory/sampleB/Job2.PDF
I have also tried a new chip soldered on an empty board, without any load, but I have the same voltage on the output of reference 4.6V.
The layout can be found on the location:
https://github.com/bogdan-tirzioru/Powersupply/tree/master/factory/sampleB/Gerber
Any idea what could be the problem? Does anyone used this chip ?
Logged
aheid
Regular Contributor
Country:
Re: Voltage reference max6070
Reply #1 on:
January 24, 2020, 08:46:47 am »
Just for kicks did you connect a load resistor testing it alone? Also, is this part from reputable dealer or random Chinese seller?
Logged
bogdant
Regular Contributor
Country:
Reply #2 on:
January 25, 2020, 05:23:36 pm »
Initial did not connected any load, but after you tell me about it, I did connected 22k resistor and make it worse , now I have a short between In and Out.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
