I could exploit that "switch" related effect then by putting the say a 2.5V bias on the diode's input, capacitor coupling the signal to here, and then having the diode's output running to ground? I can see how having the diode always strongly on, rather than the Horowitz and Hill diagram way of being just on the threshold of turning on, would mean the signal amplitude didn't cause much change in current, so no voltage drop changes here, but what about compensating for temperatrue effects, I guess this method wouldn't provide any asistance on that matter?
P.S. If I wasn't clear enough earlier, I have multiple channels feeding fast signals to peak detectors (envelope detection) to track signal amplitudes. It is too fast for any of the op amps I have to hand, so I' using the passive diode, capacitor and discharge resistor type peak detector. The crucial thing is to ensure that temperature variations or manufacturing variations between the diodes (or transistors serving s diodes) on the separate channels do not cause the amplitudes of the signals on the different channels to individually lose different amounts of voltage between the amplitude of the incoming signal and the amplitude measured on the peak detector. They all need to lose the same diode drop voltage amount, or all lose none at all though I don't think that is possible without op amp usage.
