Hi all,
this is an electricity question, I want to develop a dim bulb tester, with a lamp from 60w and a second one from 40w.
What I have already, a variac, with in front a decoupling transformer from 240VAC.
The variac gives supply to the dim bulb(s), now is the question, what kind of switch I'm going to need, to put between lamp 1 and 2? Why the split? I have enough 60w old stock lamps, but fewer from 40w.
So I can put the lamps in series (100w), or decoupled (60w). The lamps also going to be used as load for a digital Volt and current meter.
From there the current goes to an outlet, that comes out the cable gutter. The wooden plank, will be mounted against a wall, with self-made distance buses, to protect the cables on the backside.
Look at the rough pictures I made, to get more sight of the project, the plank has to cut to a smaller format, also the cable gutter. And has to be painted as well, so it looks neat on my work bench.
Of course, every safety rules going to be applied. It's just the switch that concerns me.
Thank you for the help in advance.
