Hi all,
I have a powered RFID tag that consumes very little current (~2mA). I would like to use a high side current sensor to read the current... however the load of the RFID tag is low compared to the range of the current sensor (let's say 1-10mA).
Is there a way to proportionally increase the current draw from the RFID tag to somewhere closer to the middle of the sensor range, ie. 5mA ?
So when I say proportionally increase, for example if the RFID tag current drops to 1mA, the current being seen by the current sensor would also drop by 1/2 to 2.5mA
Hope this isn't a silly question! I know another option is to change the R_sense of the current sensing device but if possible I would not like to try and modify the surface mount part if I do not have to.
Thank you
