Author Topic: Digital clock project error  (Read 652 times)
Offline haygarth17Topic starter
« on: July 11, 2024, 05:47:03 am »
I did built with my grandsons a digital clock bought from AliExpress. This is product I bought:
https://www.aliexpress.com/item/1005006658584103.html?spm=a2g0o.order_list.order_list_main.15.28a11802ENG6xd
The electric scheme and the display with error code is attached.
I can change hour and minute, date as well, all the settings actually the issue is the clock will always display this weird CSCS code and doesn't remember any settings I set. The seconds dot doesn't flash as it should and the only thing I can see when out of settings screen is this CSCS error.
Any help please.
Online retiredfeline
Re: Digital clock project error
« Reply #1 on: July 11, 2024, 08:11:01 am »
This is a wild guess. I think the CSCS message is coming from the firmware and maybe means Clock Stopped. Check if the lithium cell powering the DC1302 real time clock chip is flat.
« Reply #2 on: July 11, 2024, 08:28:05 am »
Thanks for suggestion.
I did check the CR1220 battery. It has 3.2V, which should be OK.
Offline mikerj
« Reply #3 on: July 11, 2024, 08:31:48 am »
I'm pretty sure you have the third 7 segment display installed incorrectly, it needs to be upside down on these clock kits.  However check the build instructions very carefully, they may have changed the design so this isn't needed.
« Reply #4 on: July 11, 2024, 08:44:10 am »
I did installed it the same with the seller picture (see attachment) and the way I did see it done in a YouTube video for same item.
Or maybe I don't understand what you mean by "third 7 segment display"
« Last Edit: July 11, 2024, 08:47:20 am by haygarth17 »
« Reply #5 on: July 11, 2024, 09:13:54 am »
It might be something related with the clock, like Clock Stopped, because it is very weird the LEDs for seconds (the ones located in the middle of display) aren't blinking as they should. What should I check to see if clock does work?
« Last Edit: July 11, 2024, 09:15:48 am by haygarth17 »
Online wasedadoc
« Reply #6 on: July 11, 2024, 09:15:13 am »
Not relevant. All four digits are in a single module.
« Reply #7 on: July 11, 2024, 09:18:57 am »
Yes, they are a single module.
Online wasedadoc
« Reply #8 on: July 11, 2024, 09:21:09 am »
If you have a multimeter check the voltage at U2 pin 7. If close to either 0 or 5 that suggests the oscillator is not running.
« Reply #9 on: July 11, 2024, 09:45:19 am »
I did check it in two cases:
1. with external power ON: pin 8: 3.2V,  pin 7:0.24V, pin 6:3.37V, pin 5: 0V, pin1:5.09V, pin 2:0.31V, pin 3:0.43V, p4: 0V
2. without external power: pin 8: 3.2V,  pin 7: 0V, pin 6: 0V, pin 5: 0V, pin1: 0V, pin 2:0.14V, pin 3:0.29V, p4: 0V
Online wasedadoc
« Reply #10 on: July 11, 2024, 09:57:57 am »
Those voltages seem ok.
« Reply #11 on: July 11, 2024, 10:01:21 am »
Below is the PIN description I found on Google for U2.
Online ledtester
« Reply #12 on: July 11, 2024, 10:30:19 am »
Here's an idea: remove the DS1302 and see what the clock does.
« Reply #13 on: July 11, 2024, 10:36:42 am »
Thanks. I did it and the CSCS message is still there.
The only difference I see is I'm unable to enter the settings anymore. (The way you enter the settings is to keep both S1 and S2 button pressed for at least 3seconds)
Offline m k
« Reply #14 on: July 11, 2024, 11:24:59 am »
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-YFE
The following users thanked this post: haygarth17
Online wasedadoc
« Reply #15 on: July 11, 2024, 12:28:06 pm »
https://www.analog.com/media/en/technical-documentation/data-sheets/ds1302.pdf
Recommended crystal load capacitors are 6pF, not 22pF.
Can you get the correct time and date while using the settings buttons?
Offline mikerj
« Reply #16 on: July 11, 2024, 02:34:05 pm »
Ok the design has changed, the earlier versions of this kit used discrete modules and one had to be installed upside down.
Online Kim Christensen
« Reply #17 on: July 11, 2024, 02:56:50 pm »
Check for solder bridges. Use a magnifier if your eyesight is dodgy.
For example, this soldering looks a bit marginal. There may be other joints like it:
« Reply #18 on: July 11, 2024, 11:08:51 pm »
Yes, I  can, but they are not saved. Once I move to time screen they are lost.
« Reply #19 on: July 11, 2024, 11:13:28 pm »
I will check and refresh all soldering I have access to now. Many of them are covered by the display and that one I can not remove with the tools I have. More than this I'll try to change the oscillator and if all of this will not work maybe I'll buy another kit and do the work more careful.
Thanks all for your inputs.
« Reply #20 on: July 12, 2024, 02:18:35 am »
Just to let you guys know, I did change the oscillator and the error doesn't  go away nor changes.
As I mentioned I'll purchase another kit and hopefully that project will end well so my grandkids will be happy.
Thanks.
