Once that LED display is soldered in, you've poured the cement and cannot access solder joints underneath it. Good you got it working.
A different chinese clock kit that was showing "NSNS" except when setting the time.
https://www.eevblog.com/forum/beginners/completed-diy-kit-but-not-working
Thanks for that information. Pretty much same circuit and error caused by Clock Stopped issue.
