all this to save a diode ? or even a rectifier bridge ?
a simple 3-4 amp diode is way sufficient if you regulator as 1 -1.5 Amp max output
dont tell me you are afraid of a 0.6v drop
and for the second part
a reverse diode is okay on the regulator pins, once again the simple cheapest is another diode in serial with the output, nothing will come back in reverse
normally put before the mosfets loads but you have may schematics on the web about variable loads, check them and adapt your power stage
Please forgive my ignorance, but I'm not quite following. The VIN has a mosfet for rpp, but that was because I wanted to learn how to do that, and it was my first design with a mosfet that I chose. I just keep using the same supply for my projects. I think that is pretty common for hobbyists to stick with what they know. However, I do realize something like a Schottky diode would work in place of the mosfet. But the mosfets are $0.36 each, so I am not worried about the price. i suppose if I were making thousands of the units...
For rpp of the battery that is discharged, anything that I use has to be able to withstand the current that would be carried. In this device, up to 45A. It also cannot cause a significant voltage drop. I do intend to be able to read IR of the battery that is being discharged, and will use the secondary leads from the battery that connect to the voltage sensor connector. This is essentially a balance connector for the battery. Ultimately, it probably will fall to the end user to not plug the battery to be discharged in backwards. But some people will. It will be good for me to know the likely parts that will get damaged so I can replace them if needed.
