I just acquired a couple of oscilloscopes and have been putting them through some basic testing with Lissajous patterns, Youscope, Oscillofun and so on. One thing I am noticing (and wanted to confirm with others who are more experienced) is the great deal of interference/inaccuracy on the outputs from my laptop "wave generator" software using the 1/8" phono plug.
Let me explain... I am using VA (Visual Analyzer here)
http://www.sillanumsoft.org/ I have left and right outputs to a 1/8" phone plug which I cut on the other end (from a pair of cheap headphones). I connect both probe grounds to the single common bare wire, and tips of probes to left and right wires. I have my laptop "unplugged" from the wall just in case, to avoid grounding issues through the scope.
When I look at my waves individually, there is a lot of "cross-talk" or interference. That is, if I am looking at the sine on my left channel (A) but have the right channel (B) off, it looks ok. As soon as I turn up the volume on the other channel (which I am not looking at) the sine wave which I am viewing starts to show signs of the other one on top of it. So if the waves are similar in frequency, I start to see "beats" appearing.
Same thing happens when I reverse the situation. I believe this is screwing up some of the clarity of my Youscope and Oscillofun demos, and also the symmetry of my Lissajous patterns is not perfect (although to the casual eye it would look fine).
I take this to be caused by using cheap headphone wires that have no shielding between left and right channels, and a common ground. That is why using a laptop for producing more than 1 wave at a time is a bad idea.
The other thing I noticed is the square wave coming off the laptop from this software has a "ringing". Meaning it rides up, overshoots, then oscillates a bit until it gets flat, and same thing on the way down. In contrast, when I check against my scope calibration 0.5V 1kHz reference it is a beautiful clean signal.
Is there any way to clean up the laptop output better so it can be used for some basic demos, or is it just not designed properly for a clean signal out of a phone jack? I can't see any way to isolate it unless it had 2 separate jacks for left/right (like RCA type) that could have physically separate cables. Unless I found a 1/8" phone jack and just wired up 2 separate shielded cables so they don't physically touch each other along the way.
