Author Topic: Reading a li-ion with a 1v adc  (Read 1543 times)
Offline solexiousTopic starter
« on: February 29, 2016, 12:59:09 pm »
Hello all,
I'm trying to read the voltage of my power source for my esp8266 with its inbuilt adc. Ideally I want to use as full of the 0-1v range of it's adc so a simple voltage divider doesn't seem to be the answer to my problem.
Is there a better technique for reading 2.8-4.3v with a 0-1v adc?
Cheers
Sol
« Last Edit: February 29, 2016, 02:07:22 pm by solexious »
Offline jeroen79
Re: Reading a li-ion with a 1v adc
« Reply #1 on: February 29, 2016, 01:46:20 pm »
Why would a voltagedivider not work?
Just scale it down so that the max input is less than 1V and then scale it back up in the software.
« Reply #2 on: February 29, 2016, 02:07:09 pm »
I would if I was wanting to read 0-4.3v but ideally I want to use the adc's full range to read 2.8-4.2v rather than lose resolution scaling it up in software.
Offline jeroen79
« Reply #3 on: February 29, 2016, 03:25:56 pm »
Put a zener diode between the + and the voltage divider to take 2.x V off the battery voltage.
Offline hamdi.tn
  • Country: tn
« Reply #4 on: February 29, 2016, 10:43:38 pm »
one option is to use basic opamp circuit and a couple of resistances will do that for you ... subtract Vbat  - 2.8V with a differential than apply that to a voltage divider of 1/1.4
second, if you can change the negative voltage reference of the adc, then move it up to 2.8V and scale down your Vbat by 1/1.4
