Hi everyone
I have got a Seasonic X 850W PSU which refuses to turn on: 5VSB goes to 0 and PWR_GOOD is always at 0V; all lines (+12V, +3.3V) are at 0V and the relay does not switch.
After a lot of struggle I found out a shorted IC with refdes "U4". After having desoldered it, 5VSB remain stable even after shorting PS_ON line but still does not turn on (all lines are at 0V and relay still does not switch)
Can someone help me identifying this IC?
It's a SOT-23 with marking "5014T". The same IC is used on another part of the board (with refdes "U3"). I made some measurements and it seems to be a dual diode, but I want to be completely sure before replacing it.
Also, I found out that many power supplies use it, and it is sometimes replaced with a 0 ohm resistor. I tried it and the relay switches, but +12V line (and perhaps +3.3V too) goes down to 0 in several seconds.
Thanks
