Rtfm.
Rtfm. 1KX suffix stands for 2000hr lifetime, and ASQKX suffix stands for 5000hr lifetime. Yes, lower rates part can be more expensive due to lower production volume. Unless you are supporting old designs with requirement of using exact same part numbers, just go with the better and cheaper one.Darnell can list incorrect data, and it happens all the time. Always double check with datasheet.
