Error occurs simply due to wire and connector resistance, so formula is simple, R_indicated = R_true + R_wire. If you have a table of resistances for certain temperatures, just add the wire resistance to those values and directly look up the indicated temperature. 3-wire differs from 2-wire such that you only add the difference of resistances between the two main wires and connectors.
The challenge is to know the wire and especially connector resistances. With wires, it's possible to look up to maybe some +/- 20% accuracy if you know the wire gauge, but connectors are worse, manufacturers only give worst case numbers, and connectors age and give different contact resistance on each insertion.
If you think about it, if it was easy to calculate the amount of error, there would be no need for 3- or 4-wire measurement - just calculate and remove the error. But 3- and 4-wire measurement is needed exactly because the error is unknown and cannot be calculated because of lack of knowledge into the wires and connectors used.
