You said it yourself "peak power".... peak power may not be important during discharge, but it may be very important during charge.
It arguably matters
more during discharge than during charge. But again, sugar vs vinegar: you can’t compare things that serve fundamentally different purposes.
I hear on the internet you charge LIPOS on their peak discharge. If you did that for a capacitor its actually infinity.
The maximum charge rate of a lipo battery depends on the specific battery. Some allow for very high currents, others do not, and the maximum charge and discharge rates can be the same or different. Gotta look at the datasheet for a particular cell.
Capacitor maximum charge current is
theoretically infinite, but it’s not infinite
in practice because a capacitor (like all electronic components) also has parasitic resistance and inductance that WILL limit the current. And depending on the capacitor, it could actually self-destruct. Just because a capacitor can theoretically charge at, say, 100,000 amps doesn’t mean its leads and plates wouldn’t vaporize if you actually tried to do it.
And the 2000 watts is no biggy, this could easily be just the same as any other thing u pop in the wall, But i'm going to utilize the whole lot of it at once and make a "battery charger" that full charges 3000farad supercapacitors in 10 seconds.
The amount of power available at your mains outlet is not infinite. That’s why, for example, charging a Tesla at home is very, very slow if you don’t have a special high-power EV charging system installed.
Not that any of this matters. The energy density of supercaps is so much lower than lipo that they’re simply not going to displace them. It’d take a quantum leap in energy density for them to become competitive.
Much nicer. Just imagine all the $$$... all for me... all for me...
Trust me, I’m not even the slightest bit concerned about you out-earning me with this, since there’s literally
zero chance your idea will work.
The other thing is it probably doubles as a car jump starter, if you can get a cable to inside your house.
They already make portable car jump starters, as well as ones that plug in. Nothing new there.
