Hello,
I am in the process of building this circuit and need info help with a few things.
The 4of275v capacitors, is it 4 capacitors or one? And how would I connect them to the wire?
Where it says 1/4" gap, do I actually leave a gap between the wires?
What wires would you recommend for the antenna and what comes out of the ignition coil?
Thank you
