Hello,
Please check this:
https://www.digikey.com/en/products/detail/molex/0009483054/863356I need the same type of bottom entry receptacle but instead of the hole being single pin i need it to be wide.
the reason is that i design a replacement psu for a device but it has 2 versions, each version with different connector pins placement (very close though)... so I thought instead of putting 2 connectors i could check to see if there is a solution of using one connector which should be cheap as well.
i don't want to make any daughter board or so, one board only.
regards,
