Flowing my previous topic about people meddling with my car and wanting a deterrent I am still suspicious, Changed the oil today and the sump plug was loose if not part undone, never happened before. I also have a nail in the back tire on the offending side of the car the MOT test told me. So plan is that I'll set up a light in the car so that anyone touching it will set it off.
I can preferably use some sort of touch sense or have to resort to pir sensors.
Anyone any idea on how to achieve the touch method ? I assume that it's a capacitive measurement ? Once again the problem of needing to use the physical ground as "earth" for sensing a common side for vehicle and "toucher" (scumbag)
I would go with the camera setup, either infra red or even visible light, if you have the car in such a position where you have a good place to mount the camera. The actual security cams are much better than web cams because web cams stop working sometimes for almost no reason. If not anything else though a web cam will work for a while and maybe if you get a good one it will work all the time, but you'll also need a dedicated computer for that running 24/7. The security cams of today have exceptional detail too, and can detect motion, or you can just let it run constantly and only check it if you see something has been tampered with.
If nothing else, perhaps a light in the car can come on randomly and that way they will never know when it might turn on again.
I've had my fair share of this kind of thing so I know exactly where you are coming from.
An extreme example was one of my front side lights was replaced with a different color lens. No kidding. The car had orange side lights on both sides, then one day it had orange on one side and clear on the other side, and I have before and after photographs to prove it. That was just nuts. It may have been one of the garages that it was serviced in, but they never said a word.
They also have cameras now that can work in very low light so you may not even need an IR illuminator with that kind. The regular security lights come with a set of IR LED's mounted right on the front of the camera so you don't have to get a separate IR source.
The security systems are exceptional too. They store the video on a hard drive. They have all kinds of alarms too even audio as well as visual. if something is detected, the video starts recording onto the hard drive. A 1TB hard drive lasts a long time too, several months, and then you can just record over it when nothing has gone wrong with the car.
The best bet is to go covert on this though so you can catch who is doing this and have evidence on hard drive or tape. A hidden camera is best so they do not know the car is being monitored all the time. If they find out it is being monitored, they may find another way to cause damage, and it would become that much harder to stop them in the future.
What else would be cool to set up would be a dummy camera pointed in the wrong direction while the hidden camera catches everything. For example, one of those rotating cameras that rotate back and forth maybe 180 degrees. When it happens to point in the other direction, they may be tempted to try to fool the camera, thus getting caught red handed. This should probably be a last resort though because it may just scare them into doing something else.
One of my neighbors got their wallet stolen out of the car in the driveway. Why they left it in there I have no idea.
Another neighbor had someone scratch the whole side of his car with probably a key. Right down the whole length of the car. That's nasty.
Good luck.
