Hi all, I just cannot get my head around this little bit of circuit. It's taken from the schematics of the 80 column board of an odd French computer (the Goupil 2). So we've got a 14.7456 MHz clock hooked up to a 74LS93 which creates a sync pulse for the 6845 video chip. The output (pin 8 -> clk) seems to be running at 1.638 Mhz - the input frequency divided by 9. Which seems wrong to me, I would expect it to be divided by 10. So I'm trying to work out if this is intentional or not. But I cannot for the life of me understand how the 74LS93 is set up, with the QA and QD outputs connected to the resets and how this creates the output. Can anyone help me? Many thanks in advance!
