AC, this changes quite a bit. Yes, the AC coils have a lower turn voltage range because of the peaks in the swing of the AC.
Also, taken from the datasheet:
Minimum switching current 5 mA signalling circuit *** This usually means once switched on, this is the amount of power which can hold the relay in place.
Minimum switching voltage 17 V signalling circuit
But read just above:
Control circuit voltage limits 0.2...0.75 Uc at <= 122 °F (50 °C) drop-out
0.8...1.15 Uc at <= 122 °F (50 °C) operational
***This is 19.2vInrush power in VA 30 VA at 68 °F (20 °C)
***This means around 1.25amps to switch.Hold-in power consumption in VA 4.5 VA at 68 °F (20 °C)
***This means around 188ma to hold. These numbers make a lot more sense...0.80, or 80% of 24v = 19.2v at 122 degrees. The lower 17v figure is probably minimum at room temperature, not a good choice for guaranteed operation at all specified temperatures.
Next question, will an optocoupler output be sufficient for your detector. What do you need to switch, an AC or DC device and at how many volts?
