I want to use my Arduino to log my solar panel output voltage and current. To measure the panel voltage, I though of using a simple resistive divider, but I am not sure if my panel can peak above voltages that I've seen (~34VDC max). I guess I could set up the network to split 50V to 5V and 45V, but that decreases my resolution. That probably doesn't matter enough for this application though. I was thinking of a 4.7k/47k divider (or a 50k, 25 turn pot).
Any problems with that idea or a better solution?
The current will be measured using a hall effect type of current sensor, or I will build a current shunt and use an op amp.
