Unfortunately red the last post too late; already send to manufacterer.
Relax
Sit back, forget about it. Wait for the board to arrive. Part of this journey is about learning from mistakes.
I have so far made 4 PCBs and another in the post. The 2nd threw a curve ball reversed polarity on one of the footprints. Correctable. The 4th only suffered from Left and right being the wrong way round on the stereo channels of an output jack.
EDIT: the first and second came out of the box and worked perfectly. Very satisfying.
On the reversed polarity, it is critical you treat the board very carefully straight out of the womb. Do not apply an unlimited current supply to it the first time it receives power. Not unless you like blue smoke.
Put it on a bench power supply and ease it up from low current. Start at the minimum current you expect it to draw. On the ESP8266 100mA is more than enough. Power it on, wait, don't panic, let it settle first. If it current limits at a low voltage and nothing happens you might have a problem. Check for hot components, but if you use your fingers, be careful. I have had a blister from finding out the polarity was backwards on an ATTiny85. "Is that hot... *&#! YES! That's hot!"
If it current limits slightly, give it more power. If it stabilises out of current limit, then thats what it's consuming. If it's high, check for hot components.
If you have any problems.. "Though shalt check voltages." and proceed from there. By being careful and slow with the current and you can power up and test a board with a dead short on it without blowing anything up.
You seem to have spent quite a lot of time and diligence on this, so I expect you will be absolutely fine! Good luck.
