Author Topic: Dell LCD TV turns off by itself after a few seconds  (Read 2188 times)
Offline kasumykuTopic starter
« on: April 21, 2019, 05:50:15 pm »
Hi everyone,
I just got a Dell Tv W3207C. It powers up, backlight comes on for a couple of seconds then it shuts of by itself. Only once I had it on for a bit longer and I could see onscreen menu for a brief moment then it disappeared and it shut off again.
Things that I tried and found so far:
-looked for obvious burn marks, swollen caps: seem to look OK
-checked power board output voltage: not OK. 3 pins should read 5Vdc but instead they read 1.591Vdc as bellow
Power board has 3 output connectors:
1st connector: +12VS reading 11.8Vdc
                      GND                0Vdc
                     +5V                 1.591Vdc
                     +5V2-STBY       5Vdc
                     +3V                 3Vdc
2nd connector: +24V             24.32 Vdc
                       GND              0Vdc
                       ON/OFF         0.466Vdc
3rd connector: GND              0Vdc
                     +24V              24.04Vdc
I removed T-con and inverter connectors one at a time to see if there is any difference in the output voltage but nothing changed.
I'm not sure if I really narrowed it down correctly to the power board or there's more to it. I also searched online for service manual and no luck.
Any advice would be really appreciated because I don't really know where to go from here due to my little knowledge of troubleshooting electronics to component level.
Thank you in advance!!
Offline thinkfat
    • Matthias' Hackerstübchen
Re: Dell LCD TV turns off by itself after a few seconds
« Reply #1 on: April 21, 2019, 08:09:49 pm »
Check all power rails for ground shorts. Might be a cracked filter cap. Check for heat sources, freeze spray can be helpful.
Gesendet von meinem Nokia 6.1 mit Tapatalk
The following users thanked this post: kasumyku
Offline dzseki
  • Country: hu
« Reply #2 on: April 21, 2019, 08:20:12 pm »
I had a similar problem with a DELL mointor before, there, some of the CCFL tube connectors were "burnt". As there were some sort of preformed conductive rubber thingies those were holding the CCFL tubes in place and making the electrical contact too to the inverter. Some of them got corroded and failed to make proper contact and it was shutting down eventually. This monitor used an LG panel I think.
I managed to repair this with soldering all the CCFL tubes with a thin wire to the inverter contact, while I left the rubber stuff there for the mechanical support.
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, EMG 1172B signal generator, MEV TR-1660C bench multimeter
Offline Brumby
« Reply #3 on: April 22, 2019, 01:33:39 am »
This may not be relevant, but it is a curiosity question:
Is this 1.591Vdc always around the same value - or does it change?  If it does change, what is the timing?
If you have disconnected all off-board connections and the voltage is still low, then the likelihood there is a problem on the power board is going to be high.  Can you get a good close-up photos of this board - top and bottom would be good.  (Remember - good framing, good lighting and good focus make such photos more useful.)
Offline MosherIV
« Reply #4 on: April 22, 2019, 05:32:04 pm »
Hi
Good work so far.
Capacitors can fail without outward signs.
My bet is on capacitors on the 5V rail gone bad.
Try soldering new cap across this rail and see if the monitor starts working.
Offline thinkfat
« Reply #5 on: April 22, 2019, 05:43:48 pm »
Hi
Good work so far.
That do not make sense, it is likely a leaky capacitor or a short. Soldering good caps over bad ones will not make it work.
« Reply #6 on: April 23, 2019, 12:38:35 am »
Thank you all for the responses!!
1.591Vdc is constant, doesn't change.
I have attached a couple of photos of both front and back of the power board.
Please let me know if you need more up close pictures of a particular area/ component.
I really appreciate the advice but I'm still a newbie and need to mention that I only have basic knowledge about electronics and I'm learning things everyday from people like you, so please bear with me :-[.
I'm not entirely sure how to check for ground shorts. I'm assuming that I need to disconnect the power, set multi-meter to resistance then attach one lead to ground and the other to each of the output pins that I mentioned earlier and look for very low resistance, something like 0.1 to 0.3 ohms??
That will be my next step if the power board doesn't do the trick.
Hi
Good work so far.
Thanks for the encouragement!
I think I found the cap that's related to the 5V rail (please see picture attached). It looks like its a 10V 1000uF , the positive lead of the cap is connected to the 3 pins of the 5V output.
I removed it from the circuit and its reading 887uF.
Offline Brumby
« Reply #7 on: April 23, 2019, 01:30:00 am »
Good job on the photos.   :-+
Unfortunately, nothing seems to jump out at me - but I've not had a lot of experience with TV switchmode power supplies.
Photos are always good to have, though.
Offline davep238
« Reply #8 on: April 23, 2019, 09:02:15 pm »
If you just got it, can't you return it rather than trying to fix it?
Offline mariush
« Reply #9 on: April 23, 2019, 09:18:44 pm »
It could be that the 5v output of the power supply is good, but something at the other end of the cable is shorted or with problems, causing too high power consumption from 5v
Think of it like the power supply entering current limit mode and limiting the output voltage to 1.59v
You could try disconnecting the 5v wire(s) from the connector and placing a multimeter in current mode between the connector and the wires to see if the current is excessive or not.
If you have  a decent clampmeter that can measure current in DC mode, then simply isolating the 5v wires and inserting them through the clamp of the meter could be enough for a quick test.
Offline MrAl
« Reply #10 on: April 23, 2019, 10:22:42 pm »
Hi everyone,
                      GND                0Vdc
                     +5V                 1.591Vdc
                     +5V2-STBY       5Vdc
                     +3V                 3Vdc
                       GND              0Vdc
                       ON/OFF         0.466Vdc
                     +24V              24.04Vdc
That's what happens when the electrolytic caps go bad.  You said you visually inspected them but maybe you have to do some electrical tests.  I've had same thing happen on an AOC tv set and other things too.
