Author Topic: Definitive Capacitor Identification Chart (w pictures)?  (Read 17184 times)
Offline ziplock9000Topic starter
« on: January 10, 2017, 10:30:46 pm »
I've been looking for a definitive capacitor type identification chart for weeks now that includes visuals and have not found one that covers all of the ones I have or have seen. It seems even the most extensive ones I've found on the internet are often missing the ones I have.
Does anyone know where one exists and better still one that includes not only the visual identification, but how to read the values?
Thanks.
Offline Benta
Re: Definitive Capacitor Identification Chart (w pictures)?
« Reply #1 on: January 10, 2017, 11:58:59 pm »
I've never seen something like that, and doubt that it exists.
« Reply #2 on: January 11, 2017, 12:07:44 am »
I've seen partial charts, partial lists, galleries of images for types. But they have all been bits and pieces and not the big picture.
So I'd not be surprised if there was one and tbh more surprised there isn't one.
Potentially a good project to crowd source here on the EEVBlog. People could upload images and we could help identify them, building up charts as we go?
Offline tautech
« Reply #3 on: January 11, 2017, 12:16:29 am »
There's a handy little chart in the Jaycar catalogue but ATM my internet is so slow it would take a age to download it and snip it out for you.
https://www.jaycar.co.nz/catalogue
They used to give a card chart away as a handout at the counter that had 4 and 5 band resistors, a capacitance chart and LED resistor calcs and I'm pretty sure you can snip them all from the catalogue.
« Reply #4 on: January 11, 2017, 12:20:32 am »
I just had a quick look at the image of the one in that catalogue on page 7. It's nowhere near extensive enough. It doesn't show the physical images of each capacitor type and the codes for each type. Thanks though.
Offline Vtile
  • Ingineer
« Reply #5 on: January 14, 2017, 09:42:05 pm »
Compose a such chart and share with the community. I'm sure you will get plenty of help for such project from here if you get stuckt.
Offline tautech
« Reply #6 on: January 14, 2017, 10:38:27 pm »
Thanks for reminding me to look further into this.
A few minutes Googling find this image that's probably a good starting point for such a project:
Another for old Mica caps that are rarely seen today:
And this one for simple unit conversion:
BTW, I've grabbed the first pic and started overlaying some text in it. It's a 22Mb jpg so will need some editing before it's suitable for up and downloads. There's a couple of obscure ones I don't know but when it's finished others will let us know what they are and it'll be easy to fill in the missing/unknown ones and upload again
« Last Edit: January 14, 2017, 11:30:05 pm by tautech »
The following users thanked this post: Cliff Matthews
« Reply #7 on: January 15, 2017, 09:57:13 am »
Put the high res 22M image on Tin's Xdevs site, and link it here, plus put a 1M lower resolution imge in the forum as backup. That way the high res images are available for those that want them, while the low res one is fine for those who do not.
« Reply #8 on: January 15, 2017, 10:42:05 pm »
Yeah I proposed doing this in Reply #2.  Hopefully I can get around to it on here at some point.
The following users thanked this post: Vtile
Offline tautech
« Reply #9 on: January 18, 2017, 09:59:48 am »
Some small start that will need some input and corrections.
1. Dipped MLCC ??
2. Dipped HV cap, sometimes Y rated
3. Ceranic disc
4. Ceramic cap dipped
5. Tantalum ?
6. Solid Tantalum
7. Tantalum ?
8. Film cap X2 rated
9. Film cap X2 end view
10. Film cap
11. Film cap polarised
12. MLCC SMD
13. Varicaps ?
14. Tantalum bead
15. Aluminum Electrolytic, polarised
16. Supercap
17. Tantalum SMD
18. Aluminum Electrolytic SMD, polarised
19. Aluminum Electrolytic, Non-polarised
20. ???
Corrections and additions welcomed.  :)
By all means grab the txt file below and edit and place it back with a reply.
« Last Edit: January 18, 2017, 10:24:43 am by tautech »
The following users thanked this post: ziplock9000
« Reply #10 on: January 18, 2017, 10:03:21 am »
Thank's mate. I'll start recording this. Maybe in some sort of public wiki rather than something like a public Google Docs.
Does EEVblog have a wiki by any chance?
Offline bktemp
« Reply #11 on: January 18, 2017, 10:05:23 am »
4 is probably a MLCC
5 is a foil capacitor made bei WIMA (probably FKS series)
6 is also a foil capacitor, but without the additional protective case (only thin film of lacquer)
11 there are also similar looking electrolytic capacitors, so it is hard to tell. (>10uF it is probably electrolytic, <1uF is foil capacitor). This one has 3.9nF, so it is a foil capacitor.
12 the large WIMA one is a foil capacitor: http://www.wima.com/EN/tpl_products_smd_overview.htm
There are also similar looking ones like nr 6 but SMD.
13 is a feed through capacitor
20 could be a supercap or a battery or something in between
« Last Edit: January 18, 2017, 10:13:31 am by bktemp »
Offline tautech
« Reply #12 on: January 18, 2017, 10:10:57 am »
It's in no way ready for such tributes if any.  :-//
When I first put the image up, it was straight from the source where I found it, so if you Quote it the URL becomes visible and anybody then can grab it and have a go themselves.  ;)
Daves Wiki is on his main EEVblog site.
Offline tautech
« Reply #13 on: January 18, 2017, 10:13:46 am »
11 there ara also similar looking electrolytic capacitors
Yep, I got a few nearly right and I think it best to leave some corrections come in for a day or so and then we can all have a good  :box: over which we call what.  :-DD
« Reply #14 on: January 18, 2017, 11:14:40 am »
Well I've created the Wiki and added the first set of images.
If someone could start populating the names that have been suggested so far please?
Just an FYI, please don't remove suggestions from other people just yet unless you're an expert as we are still crowdsourcing this.  ;)
http://electronicsreference.wikia.com/wiki/Capacitors
There's prolly a lot more we can do in the future with this wiki too.
Offline CatalinaWOW
« Reply #15 on: January 18, 2017, 11:28:34 pm »
I started taking pictures of a couple of the common types that I have which are not yet in the photo and realized a few things.
1.  I am going to have to do quite a bit of photo set up to get decent pictures.  Maybe even a microscope.
2.  A scale will be useful for identification, particularly for those who don't know already what the type is.
3.  Much of the critical information is not in the color or shape.  The ceramic type for example.  Not sure how best to flag this in an identification chart.  Maybe an inset for the generic type with the inset focused on identification of the variations.  Same thing could apply to electrolytic types.
Offline timb
    • timb.us
« Reply #16 on: January 18, 2017, 11:54:04 pm »
I've actually been working on something like this. Basically a A3 size component reference chart with pictures of different types of common passives, showing what they are and how to read off the codes (if they have any).
I'd be happy to post it here and then add to it as people send me high quality photos of new types. :)
Offline free_electron
    • SiliconValleyGarage
« Reply #17 on: January 18, 2017, 11:58:25 pm »
1 is a silver-mica.
4 is an mlcc ( essentially a 0603, with leads welded on and dipped in epoxy)
5 6 ad 7 are film caps. The red one is a wima. The silver one is siemens and the black one probably a sprague. These can be different types of films. Polyester, polyethylene, polysulphone,
10 and 11 are film caps. Polysterene or polyester. These are NOT polarised !. The stripe indicates the terminal connected to the outer electrode. That should be connected to the lowest impedance node. That way the outer electrode 'shields' the weak driving node.
13 are feed-trhru capacitors.
There are many missing. Solid tantalums, solid aluminums, sibatits, to name a few.
And when to comes to mlcc.... class 1 , class 2 class 3. Etc ..
Same for those smd electrolytics. They could be oscons , sold electrolyte , vibration resistant ( those have thicker plastic shims that grasp the indentation in the body. Often they also have helper electrodes..
« Reply #18 on: January 19, 2017, 02:32:14 am »
At the moment just capturing all of that is the most important part, dissecting and classifying the data can some at a later point.
« Reply #19 on: January 19, 2017, 02:33:36 am »
If you could add them to the wiki I've setup it would be better. A forum might be good to collect data, but nowhere near as good as a wiki for displaying it.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #20 on: January 19, 2017, 02:39:44 am »
Cool project! I'm gonna follow this  :popcorn:
« Reply #21 on: January 19, 2017, 02:42:51 am »
Ok, I've added everyone's suggestions thus far to the wiki. I'm going to do some hi-res DSL photography of my own now and add them to the wiki.
If possible, instead of putting suggestions here, can you guys and gals add them directly to the wiki instead? Less copy and paste for me. Thanks
I'll also be adding more columns to the table as they become obvious, like "polarized" and SMD etc:D
Offline tautech
« Reply #22 on: January 19, 2017, 02:47:25 am »
I'm sure I've seen solid Tantalums like that too, they weigh like lead in your hand.  :-//
Offline xrunner
« Reply #23 on: January 19, 2017, 02:50:07 am »
What's next?
The definitive transistor identification chart,
the definitive ___________ identification chart?  >:D
« Reply #24 on: January 19, 2017, 02:52:30 am »
What's next?
Why not?
