Author Topic: DC jack that disconnects internal batteries when plugged in  (Read 5269 times)
Offline CozzmoTopic starter
« on: August 14, 2014, 03:34:23 am »
Is there a special name for this part?
Have been asked to add an external DC power supply jack to a normally battery powered item, but still retain the battery powered possibility. To avoid issues, i'd like to use a jack that disconnects the internal batteries when the plug is inserted instead of having a switch or something. I know they exist but searching hasn't got me too far (so many items to filter through) finding anything that specifically states that it works in that way. Hoping that somewhere like Jaycar stocks them so i can just pick one up easily.
Offline RobertHolcombe
Re: DC jack that disconnects internal batteries when plugged in
« Reply #1 on: August 14, 2014, 03:46:23 am »
I don't know that there is a name, its just a DC jack socket w/ 3 pins, see below example I found on google
Offline jeremy
« Reply #2 on: August 14, 2014, 03:59:40 am »
This can be problematic though, as you will lose power in the changeover. Better have some big capacitors on the power supply!
Offline wyphy
« Reply #3 on: August 15, 2014, 01:15:11 pm »
Don't know if it helps, but I've always heard this type of jack called a "normaled" jack, just like a relay's normally open/closed connections.
Offline Refrigerator
  • Country: lt
« Reply #4 on: August 15, 2014, 03:23:12 pm »
Type in "power jack" in google images and look from there.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Online tszaboo
« Reply #5 on: August 15, 2014, 03:53:02 pm »
What is wrong with powerpath controllers?
Offline German_EE
« Reply #6 on: August 15, 2014, 04:29:23 pm »
As an alternative use a normal jack with diodes in series with the two voltage sources then there will be switching without loss of power.
Warren Buffett
Offline Richard Crowley
  • KJ7YLK
« Reply #7 on: August 15, 2014, 04:46:11 pm »
IME, it is hard to find a power connector that does NOT have this feature.  That is probably where there is no explicit mention in the descriptions.
Offline dentaku
« Reply #8 on: August 16, 2014, 02:48:00 am »
Looking around this room I see that every jack that's visible to me (I use them on breadboards instead of batteries) is the three pin variety that switches when you plug something into them.
Offline AmmoJammo
Offline edavid
