that multimiter you showed on amazon looks pretty ok, if you really want the autoranging, cars usually only unse 12 volts or so on their systems so the 20 v range on the cheap chinese should be enough. i would tell you to go for an even cheaper multimeter. unless you stick it on the high voltage spark plug system it should be more than enough
