Hi All,
I have a question related to some DSP coursework for my degree (So try not to directly tell me if possible - but I really need to understand). My lecture has asked the following:
"A discrete time sinusoidal signal can be generated in Matlab as follows:
N = 0:1:100; f = 0.1; x = sin(2*pi* f*n);
where f=0.1 is the normalised frequency of the sinusoidal waveform. Apply,
stem(abs(fft(x))) and discuss the results.
Now generate x as x = x = sin(2*pi* 0.1*n) + 3*sin(2*pi* 0.25*n). Obtain discrete
Fourier transform coeffects and discuss the results. "
So from this, I get two DFT plots, and can make the following conclusions:
- The amplitude plotted is equal to the amplitude of the sin wave * N/2 (sequence length/2)
- The Frequency plot is mirrored around the N/2 point
- The DFT plot gives me multiple frequency points (rather than the 1 or for the second part 2 expected
I have noticed that if I change the sequence length to N = 0:1:(100-1), then the last point goes away, and hence the DFT plot only gives two Fourier coefficients as expected. This is obviously more correct than what my lecturer has provided, but I am struggling to see why it is making such a big difference.
In conclusion, my question is why do I get more Fourier components with a sequence length of 101 or greater in comparison to 100? I have attached the two plots as JPEG format, and can provide code if necessary.
Thanks in Advance, am happy to direct my question elsewhere, but you guys are always super helpful with my other electronics questions so thought I'd try here first.
