Author Topic: Decent Desoldering iron/station  (Read 20348 times)
Offline oxidizedTopic starter
« on: October 15, 2016, 12:52:05 pm »
Hello everyone, i'm new in this forum and i plan to stay as long as i can  ;)
Now let's go to the point.
I'm looking for a decent desoldering iron or station around 200€ (better if under ofc), the hakko fr-300 looks good, but VAT included it ends up costing like ~290€, and i want to stay far below that.
Any idea?
Offline Kuro
Re: Decent Desoldering iron/station
« Reply #1 on: October 15, 2016, 03:11:39 pm »
Dave did a video on one:
The equivalent in Europe would be this one: https://www.amazon.de/gp/product/B005CHA7IG/ref=pd_sbs_328_1?ie=UTF8&psc=1&refRID=FWW0TBQX0QSQV52JZSCQ
The universe is made of protons, neutrons, electrons and morons - March for Science 2017
The following users thanked this post: oxidized
« Reply #2 on: October 15, 2016, 05:19:53 pm »
Thanks for replying!
yeah i saw that, well i'm not sure about the quality, pretty sure he said something like "feels cheap" "Plasticky" but if it's decent then...
Offline fubar.gr
  • Country: gr
    • Fubar.gr
« Reply #3 on: October 15, 2016, 05:37:17 pm »
It's indeed low quality but it does the job and spare parts, even the whole pistol assembly, are dirt cheap and readily available everywhere.
« Reply #4 on: October 15, 2016, 05:43:59 pm »
watching the rest of the video, it seems to be better than what it initially looked and felt, if there's really nothing between this and the hakko fr300, might aswell get this then
Offline chucksticks
« Reply #5 on: October 15, 2016, 05:45:32 pm »
Offline Gyro
« Reply #6 on: October 15, 2016, 06:17:50 pm »
I believe the Proskit branded version sold by Element14 (Farnell) may be slightly better quality. It has a glass solder tube rather than plastic, different solder collection spring (compared to the video) and possibly better seals too I think. I haven't been able to compare them side by side (I have the Proskit), or done any price comparison either. Most part are available as spares though, including the gun. Mine works well anyway...
http://uk.farnell.com/proskit-industries/ss-331bc-f/desoldering-station-60w-240v-eu/dp/2320603
P.S. Changing the 12V fan for a 24V one makes it quite a bit quieter as it is running at 15-17V!  :o
EDIT: Some useful additional information (The Duratool looks the same as the Proskit):  http://www.vintage-radio.net/forum/showthread.php?t=125263
« Last Edit: October 15, 2016, 06:24:00 pm by Gyro »
Best Regards, Chris
« Reply #7 on: October 15, 2016, 09:31:41 pm »
Interesting, might get a proskit, or a duratool if i'm able to find one, Thanks for the reply and the useful suggestions!  :-+
Offline GreyWoolfe
  • NW0LF
« Reply #8 on: October 15, 2016, 11:45:30 pm »
I have the ZD-985 and it works well for what it is.  It's not a $2,000 JBC desoldering tool, but I have found that if the lead fits into the tip, I can desolder it.  Any tool like this requires maintenance.  Make sure you keep it clean.  Don't release the trigger until a second or 2 after you remove the tip from the pad.  Solder will harden in the gun and it is a pain to clear, not that I have ever done that  >:D  Cranking it to full power will make it easier to clean stuck solder. Make sure you have some practice boards to play with.  It's not hard to lift a trace or remove a pad so practice makes perfect.  I let ham friends come and use my soldering stations but I won't let anyone use the ZD-985-I don't want them to damage their stuff.
« Reply #9 on: October 16, 2016, 12:07:47 am »
Well my first experience with a desoldering iron, was with an old pace ST 115, which was so old i had to clean it up every 20/30 pins, it was pretty good overall, but still, a pain in the a** to clean it and everything.
Anyway i might get the proskit, for ~115€ from farnell, should be pretty much like the ZD-985, but hopefully better built and assembled, if only hakko had something from 150 to 230€... ::)
Offline Brumby
« Reply #10 on: October 16, 2016, 09:52:03 am »
I have one of these as well - and I agree with what has been said.  Yes, it does feel cheap - but, from my experience, it does the job and does it quite well.  Plenty of thermal capacity.  Plenty of suction.  The solder receiving chamber can be a bit fiddly to wrangle - but you soon get to know it's idiosyncracies.  I don't do a lot of desoldering, but when I do - this unit makes it a whole lot easier.  I have found it absolutely brilliant on removing headers from double sided boards.
Offline Gyro
« Reply #11 on: October 16, 2016, 10:08:07 am »
Just one other note, I use the smallest hole (0.8mm) tip for pretty much everything (unless it won't fit up the hole obviously!). It gives best thermal coupling to the lead as well as the pad, minimising the chance of lifting the pad. Having the close fit also seems to minimise clogging... lower flow volume of solder, moving faster?
The proskit version also comes with an un-drilled tip (don't know about the others). It works well as a large high thermal mass soldering tip for those 'special' occasions. Obviously you don't use the vacuum trigger with it.
Best Regards, Chris
« Reply #12 on: October 16, 2016, 12:38:31 pm »
Alright, so it comes with different tips, or i must buy them separately? I'd prolly need all of them cause when i happen to desolder stuff, i usually encounter different sizes, from tiny ones to, for example, heatsinks, so i guess it's better to be equipped for the occasion
Offline chris_leyson
  • Country: wales
« Reply #13 on: October 16, 2016, 12:53:01 pm »
Bought a couple of PACE ST-75 desoldering stations with SX-90 hand piece at auction, they do a nice job but the diaphram air pump is very very loud, in fact so loud I dare not use it a home for fear of waking up my house mates. I might try replacing one of them with an air pump from a small spray paint kit or maybe look for a rotary air pump. Shame really as the hot air tool is quite nice.
Offline Gyro
« Reply #14 on: October 16, 2016, 01:11:38 pm »
It comes with 3 tips... 0.8, 1.0, and 1.3mm.
I bought mine s/h from a fellow eevblog member so it's possible that the solid tip was added, but was in the same accessory bag.
« Last Edit: October 16, 2016, 01:13:48 pm by Gyro »
Best Regards, Chris
« Reply #15 on: October 16, 2016, 01:16:32 pm »
That's perfect! proskit it is! Gonna buy it asap, and see if i can start my custom mechanical keyboard project. You all have been very useful, thanks!  ;)
Offline Gyro
« Reply #16 on: October 16, 2016, 03:42:26 pm »
Oh, just noticed that CPC do the Duratool brand variant. I'll never understand, they're both Farnell companies  :palm: I'm not sure which would work out cheaper in your country - CPC is UK based....
http://cpc.farnell.com/duratool/d00672/desoldering-station-uk-eu-plug/dp/SD01384?MER=e-bb45-00001001
It gives less detail of what's included, just says conical tip and the picture doesn't show anything. They list spare tips cheaply though.
As I say, I don't know which will work out better for you with the state of the £. You probably have an element14 entity in your country, certainly in the eurozone.
Edit: Just pointing this out as an option, I'm not suggesting that you change from the Proskit. I have no direct experience of the Duratool but I thought you might at least want to know that it was there.
« Last Edit: October 16, 2016, 03:59:10 pm by Gyro »
Best Regards, Chris
« Reply #17 on: October 16, 2016, 03:57:42 pm »
Yes we have an element14, but i can't seem to find the duratool variant, only soldering station from duratool, let's see if there's something else.
Regarding the tips, i don't know, what i'd tho is different tips, not really same ones...well...that too maybe, i think that after 400/500 pins, a tip is rip, but i'd need bigger one too, let's see if i can find that too. Thanks again!
Update: So, our italian farnell, is only selling the one from proskit for ~94€ exc VAT, and they're also selling a set of 3 tips, which according to the datasheet are 1mm, 1,2mm and 1,5mm which is perfect
« Last Edit: October 16, 2016, 05:29:37 pm by oxidized »
Offline Gyro
« Reply #18 on: October 16, 2016, 05:44:06 pm »
Well that certainly ties in with the "Price rises in the UK" thread in the Buy/sell/wanted section. It's gone up to £96.75 + VAT here in the UK.  ::) I'm glad I already have mine!
Glad it's worked out so well for you with price, tip sizes etc.  :-+
Best Regards, Chris
« Reply #19 on: October 16, 2016, 06:41:28 pm »
Yeah, i'm glad too :D
Anyway, i never understood why cheap desoldering station all use a "gun" style desolder stick, instead of the classic "pen"style like pace stations for example, isn't it easier to use and also easier to build than a gun shaped stick? (This is based on the fact the first desoldering station i ever used had a stick instead of a gun)
Offline Gyro
« Reply #20 on: October 16, 2016, 07:18:34 pm »
It actually works best if you hold the board vertical and use the gun horizontally. Much less chance of clogging as the removed solder doesn't fall back down onto the rear of the element. As there is no solder to apply it can be a two handed operation. The gun shape makes a bit more sense then (although the trigger could do with a stronger return spring).
Best Regards, Chris
« Reply #21 on: October 16, 2016, 07:26:22 pm »
Makes sense, well i'll surely get used to it no problems then
Offline stj
« Reply #22 on: October 17, 2016, 10:57:51 am »
i should warn people, there are 2 versions of these.
one has a switching psu - as in the video.
the other has a linear transformer.
they look the same, it's just the internals are different.
i have a Duratool branded one here with the transformer.
it has 2 problems.
1: the transformer cant provide enough current to run the heater and pump together.
when you hold the pump on, it starts to pulse in rythm with the heater.
2: the pump is driven directly from the transformer via the socket, cable & trigger.
if you hold the pump on, the connector and cable warm up!!!  :palm:
i'm waiting for delivery of a solid-state relay to fix this bs.
i suspect that's what's in the cable-tied box in the back of daves - a relay of some type.
« Last Edit: October 17, 2016, 11:00:18 am by stj »
« Reply #23 on: October 17, 2016, 12:21:44 pm »
it has 2 problems.
Wow sounds like a very bad thing, anyone with the proskit can check that, please?
Thanks for posting and warning about that!  :)
Offline Gyro
« Reply #24 on: October 17, 2016, 01:27:08 pm »
My Proskit has a SMPS, not linear transformer.  :-+
Best Regards, Chris
